| | | Forums66 Topics128,290 Posts1,058,557 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I fought this, and everything I tried, with various headers...nothing worked. I just could not get by the stock steering box, even when shimming it over as far as it would go.
This last pair of headers are shorties from a 1986 Corvette. Smallest things I've ever seen. They came within a quarter inch of being able to bolt them up, but then THAT WAS IT. Not a millimeter further.
Then out of curiosity, I turned it upside down, like people do when they mount turbos. That way, it fit beautifully, and the stock steering box can stay in the stock location too. It looks a little funky, but if everything is prepped really nice, or even chromed, it could look good. I'll have to use a J-bend to get the pipes back in the right direction, and probably have to go through the wheel well, but then my set up is perfect for a pair of future turbochargers if I want.
Wow, that'd be something wouldn't it? Twin turbo V8 in an AD truck.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have thought about that but figured if it would work someone would have already done it. Congrads. "someone". Like they say "necessity is the mother...
~Jim
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | ...And this one was a mother...
I worried a little bit about if I should install them upside down because of how hoaky it could look. But if there is a way to make them look good, I'll figure it out, that's for sure. I'd rather have real headers than to struggle with barely enough room with a pair of log manifolds and 50 hp less.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | So when you were within a quarter of an inch was that with the box shimmed over as far as it would go, or in stock position?
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Cool ! glad it worked out for you, Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | That is a good idea, any way you can shoot a picture of your set up to us?
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yes I'll be taking pictures. They're not permanent yet. I still want to take them back off and use a die grinder to clean up the interior, then a coat of fresh high temp paint.
And yes, when they were a quarter inch away, that WAS with the steering box shimmed over as far as it would go...about 1 1/4" over. Upside down, it looks like the steering box can return to its stock position, or close to it.
I was going to someday stroke my 4-bolt 350 to a 383, but if I twin turbo it, maybe I'll leave it a 350. It's a lot easier to get low compression with less stroke and the turbos simply don't need the extra displacement to make power. If I do, it'll be a torque set up, not high end horsepower.
