Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 136 guests, and 10 robots.
Topics128,281
Posts1,058,470
Members48,490
#38088 01/08/2005 4:51 PM
I havebeen given a 1977 z-28 camaro f body rear end with 3:42 gears.
Can I use this for a rear end swap on my 55.1 that has the stock rear?
Chris
Chris 1955FirstSeries
#38089 01/08/2005 7:11 PM
I am using a 1977 Trans Am rear axle in my '37. Its should be a standard GM 10 bolt. The 3.42 would be a all around street gear, good for pulling or highway driving. I swapped my 3.42 for a 3.08 because of the 6 cyl rpm range and I like to drive 65 and 70. I did have to change the spring perches because the '37 uses a 1 3/4" wide spring. Your newer truck should use the same 2" spring, so you still may have to relocate them inward or outward. Joe
