2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38088 01/08/2005 4:51 PM | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I havebeen given a 1977 z-28 camaro f body rear end with 3:42 gears.
Can I use this for a rear end swap on my 55.1 that has the stock rear?
Thanks, Chris
Chris 1955FirstSeries
#38089 01/08/2005 7:11 PM | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | I am using a 1977 Trans Am rear axle in my '37. Its should be a standard GM 10 bolt. The 3.42 would be a all around street gear, good for pulling or highway driving. I swapped my 3.42 for a 3.08 because of the 6 cyl rpm range and I like to drive 65 and 70. I did have to change the spring perches because the '37 uses a 1 3/4" wide spring. Your newer truck should use the same 2" spring, so you still may have to relocate them inward or outward. Joe | | |
