| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Does any one remember if the 1950 3100 series had a serial # applied to the frame to help with identification. If so where on the frame would it be located?? Question was asked of me by a friend in England who just imported a 1950 1/2 ton.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | No, not originally. The only serial number was the one on the drivers door post. I think English models with right hand drive also had the serial number plates on the drivers (right side) door post. The only other numbers frequently used for registration purposes were on the engine. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | That's what I thought but wanted a little confirmation to pass along. This truck was imported to England from Calif. and the PO had a new ID tag made and this is what is causing the problem with the English Gov. they don't think the # are good because the plate is new. Will pass along the info.
