2 members (66flea, 1955 1 Series), 98 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#380449 02/26/2008 11:41 PM
Does any one remember if the 1950 3100 series had a serial # applied to the frame to help with identification. If so where on the frame would it be located?? Question was asked of me by a friend in England who just imported a 1950 1/2 ton.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
No, not originally. The only serial number was the one on the drivers door post. I think English models with right hand drive also had the serial number plates on the drivers (right side) door post.
The only other numbers frequently used for registration purposes were on the engine.
That's what I thought but wanted a little confirmation to pass along. This truck was imported to England from Calif. and the PO had a new ID tag made and this is what is causing the problem with the English Gov. they don't think the # are good because the plate is new. Will pass along the info.
