0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
#379521 02/24/2008 6:56 PM
Hi Working on my 51 3600 Long Box. Have it stripped down to the frame and have ordered a Mustang II Front suspention as well as new rear mono leaf set up. Been really concidering shorting the frame to change her into a short box. Has anyone done this and any advice. I am thinking to cut the frame cut the front of the box remove 1 support per side and shorten the splash aprons and order new running boards for a short box. ?? Any advice would be great.. Or anything I have forgetten.
Thanks Robin
Robin71 #379579 02/24/2008 9:38 PM
That sounds about right, Robin. I am toying with the same thing on my '50 3600. Would like to see any of your progress pics or anyone else's that is going through the same change.
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
a.d.-hawk #379599 02/24/2008 10:26 PM
I could not imagine shortening the bed.. I really like the usefulness of the 9' bed on my 1 ton, even 8' would be too short after having 9' for so long (pun intended) grin
If you must shorten it, sounds like you have a plan.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #379630 02/25/2008 12:21 AM
9 1/4 inches from the wheelbase is all thats stopping you. check out my website the 54 with the 250 engine was a long bed
1949 SUBURBAN
Thanks guys I will keep you updated. I am going to V-Cut the frame and I will post some picks of the whole procedure . Gona weld on some tabs on both sides of the cut so I can measure exactally the distance as well as I might even do a box section on the cut section or a fish plate for added strength.
Robin
Robin71 #379818 02/25/2008 7:57 AM
i just spliced the frame on my 53 chev 3100. i put a new front section on from about the front cab mount forward. do a angle cut about 33 degres so that you have more weld surface and a stronger joint. then at least do a fish plate with no square corners. boxing your splice would be good. i have pics on photobucket.com under justin53chev
gotta love old trucks
53chev #379820 02/25/2008 8:11 AM
Robin ,
Last sunday "TRUCKS" had a whole show dedicated to shortening a early 60's long box to a short , very informative & detailed they covered the frame & bed ,the way they did the frame looked pretty strong . maybe you could search that episode on the net ???
1952 Chevy Shortbed
Photos in Photobucket
