| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 12 New Guy | | New Guy Joined: Jan 2008 Posts: 12 | Hi Working on my 51 3600 Long Box. Have it stripped down to the frame and have ordered a Mustang II Front suspention as well as new rear mono leaf set up. Been really concidering shorting the frame to change her into a short box. Has anyone done this and any advice. I am thinking to cut the frame cut the front of the box remove 1 support per side and shorten the splash aprons and order new running boards for a short box. ?? Any advice would be great.. Or anything I have forgetten. Thanks Robin
| | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | That sounds about right, Robin. I am toying with the same thing on my '50 3600. Would like to see any of your progress pics or anyone else's that is going through the same change. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I could not imagine shortening the bed.. I really like the usefulness of the 9' bed on my 1 ton, even 8' would be too short after having 9' for so long (pun intended)  If you must shorten it, sounds like you have a plan. Grigg | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | 9 1/4 inches from the wheelbase is all thats stopping you. check out my website the 54 with the 250 engine was a long bed | | | | | Joined: Jan 2008 Posts: 12 New Guy | | New Guy Joined: Jan 2008 Posts: 12 | Thanks guys I will keep you updated. I am going to V-Cut the frame and I will post some picks of the whole procedure . Gona weld on some tabs on both sides of the cut so I can measure exactally the distance as well as I might even do a box section on the cut section or a fish plate for added strength. Robin | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i just spliced the frame on my 53 chev 3100. i put a new front section on from about the front cab mount forward. do a angle cut about 33 degres so that you have more weld surface and a stronger joint. then at least do a fish plate with no square corners. boxing your splice would be good. i have pics on photobucket.com under justin53chev
gotta love old trucks
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Robin , Last sunday "TRUCKS" had a whole show dedicated to shortening a early 60's long box to a short , very informative & detailed they covered the frame & bed ,the way they did the frame looked pretty strong . maybe you could search that episode on the net ???
