2 members (TexasJim50, Gdads51),
108
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | When I step on the starter I hear a grinding noise then I release the button and it may or not happen again on the 2nd or 3rd try it works. I know many of you out there have gone thru this any help on where to start? | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | If you are asking a question as to which one to suspect, I say both depending on how long it has been doing it. I think the starter drive (bendix) is the inotial problem but when ignored long enough chews on the flywheel which will give the same symptoms even after the problem starter drive is replaced. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Engines tend to stop at nearly the same place as far as starter drive to flywheel is concerned so try turning the engine about 90 degrees and then trying it. If it kicks in every time by doing this then it's the flywheel. If a standard trans you can put it in high gear and push it a little forward or back and if an auto you will have to turn the flywheel, after pulling dust cover, or if it has a bolt in the front of the crank you can turn with that. If it's an old 235 or even a 250 you can press the fan belt tight and turn them by pulling on a fan blade.
Evan
