5 members (Otto Skorzeny, Bill Hanlon, Hotrod Lincoln, Cletus1950, Wayne67vert), 198 guests, and 5 robots.
Topics128,106
Posts1,056,217
Members48,436
#379185 02/23/2008 10:42 PM
V
V Offline
The po wired in a 10si. #1 goes to idiot light via the factory brown wire. #2 goes to starter batt term . Alt Batt term goes to starter batt term . Starter Batt terminal goes to + side off battery, from there to the horn relay.
The idiot light comes on and slowly goes dimmer with increasing RPM. Is this an idication of a bad alt or bad wiring design?
1966 C10 250/3 Stepside
1966 C10 327/3 Fleetside
1972 Buick Centurion 455/TH400
1964 Plymouth Valiant 360/A833 4spd
1964 Plymouth Sport Fury 440/727
I've got a new car....It was made in '72
Valiantsignet200,
The wiring is proper. My guess is the brushes are worn and not making contact with the slip rings...either that or there is lots of dust and dirt in the thing. This has happened to me before. Try blowing the alternator out while it's running.
Stuart
Riding in the Passing Lane
You have a bad diode trio in the alt. They are not hard to repair yourself if you get a book & follow the instructions. The diode costs less then $5 at a parts store.
1972 Chevy c10 Cheyenne Super
