3 members (Gdads51, Otto Skorzeny, 1 invisible),
179
Mod | | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 30 New Guy | | New Guy Joined: Jan 2006 Posts: 30 | The po wired in a 10si. #1 goes to idiot light via the factory brown wire. #2 goes to starter batt term . Alt Batt term goes to starter batt term . Starter Batt terminal goes to + side off battery, from there to the horn relay.
The idiot light comes on and slowly goes dimmer with increasing RPM. Is this an idication of a bad alt or bad wiring design?
1966 C10 250/3 Stepside 1966 C10 327/3 Fleetside 1972 Buick Centurion 455/TH400 1964 Plymouth Valiant 360/A833 4spd 1964 Plymouth Sport Fury 440/727 I've got a new car....It was made in '72
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Valiantsignet200,
The wiring is proper. My guess is the brushes are worn and not making contact with the slip rings...either that or there is lots of dust and dirt in the thing. This has happened to me before. Try blowing the alternator out while it's running. Stuart
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a bad diode trio in the alt. They are not hard to repair yourself if you get a book & follow the instructions. The diode costs less then $5 at a parts store. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
