2 members (TexasJim50, Sjm),
98
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | I have a 4 speed in my 1 ton,And the other day I was looking at it and found the rear output shaft has some play in it, i'm not sure how much, but by feel it isn't alot.Is this somthing I should fix now or is it normal?And can I do it with the tranny in the truck? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Does it have an open drive shaft behind it? Is the play up & down or in & out? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | Yes its a open drive shaft.The play is up&down,I didn;t check to see if it go's in and out. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make sure the nut that retains the yoke is tight. If it is the brg. has some wear in it. If it is a small amount & the trans is not noisy & works ok I wouldn't worry about it. It can be replaced without pulling the trans. It's always a good idea to change the grease in the trans & rear end on these old trucks when you get one. The grease in there can be really raunchy. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
