4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#37822 07/29/2003 4:36 AM
Junior Member
Junior Member
I have a 3 speed Chevy transmission that I received on a trade, which was removed from a '55 Chevy 1/2 ton. I think it is a later model since the date code on the side cover is "L37", which I translate to be December 3 of 1957. The part number on the side cover is 3845122. I would greatly appreciate any help with this identification.
#37823 07/29/2003 5:01 PM
Reading the hollender I got , comes up :
Case #3845121 ( Cast. #3845122) Pass. (exc. O.D.&57 close ratio); corvette 55-56 also list 3707166 with this case # cast # as 55-59 1/2ton-1ton Pass. with out OD,plus several other applications for that case, Just a guess, but it's 55-57 Pass. sedan del.3 speed, 1/2 ton to 1 ton 55 - 59 3 speed, that case was used in 60 - 63 10 and 20 chevy also, should be another 7 didget number to id trans, best I can do , hope It helps,
Jbennett
40 burb
