3 members (TUTS 59, klhansen, cmayna), 76 guests, and 3 robots.
Topics128,099
Posts1,056,501
Members48,444
#378096 02/21/2008 4:08 AM
1 Offline
guys, to move my 54'chevy coe 5700 and might have to remove the rear outer rear wheels to possibly to clear the fenders on the trailer. what size lug nuts are they and what is the safest way to do this. what tools will i need to do this. thanks.
It is hard to guess at the size socket it will take, but should be 1" or bigger. Lug nuts may not be original. If they are the same as my 2 ton, then the studs are 5/8-18, and take a 1" to a 1-1/16" socket, again, depending on lug nuts.
A good bottle jack and a strong 1/2" breaker bar should do the trick. Some extra blocks or a jack stand would add to the safety.
Block front wheel both front and back.
Loosen all the nuts on one side at the rear,
Remove all but two,
Jack up that side just off the ground,
Remove the last two nuts,
Remove outer wheel,
Reinstall the lug nuts.
Repeat for other side.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
1 Offline
thanks! anybody else have any input on what size socket to use?
When I needed to remove the lug nuts to trailer my COE the previous owner walked up with an oversize cross type lug wrench that fit the lug nuts on my COE and probably half the other trucks in three counties.
I wanted him to throw it is as part of the deal, but he didn't go for it.
You need one of those.
when i'm removing a tire i follow all the same steps as have already been mentioned as far as the size i just look at it guess and then grab a couple sockets that look to be the right size and try them but hay thats just me. but i would guess that Grigg is right in the area of what size they are.
to much to do to little time to do it all
McAllen, TX
1948 Chevy Loadmaster flatbed fire truck
http://rides.webshots.com/album/562569229snLyQV?vhost=rides
