4 members (1955 1 Series, 66flea, Peggy M, 1 invisible), 336 guests, and 5 robots.
Topics128,156
Posts1,057,017
Members48,460
I'm trying to convert my 54 3/4 ton from 8 lug to six lug and have a question. Will a 1/2 ton front axle from an AD work on my truck. And do I need anything more than the axle, hubs, spindles, and backing plates. I am trying to keep it pretty much old school. Want to start looking around here first (central/southern Indiana) so shipping won't eat me up.
Squeegebob
If I'm not mistaken, the springs are the same, but the axle is bigger, so you may need the U-bolts for the 1/2T axle. Also, try to get all the steering gear with the 1/2T axle, as the holes for the steering arms may be different. And the brakes are different.... unless you plan to change to disks in front....
Squeegebob, it is a ez swap get a 1/2 axle drum to drum with the tie rods, steering arms, ubolts, bumpers that mount on the top of the ubolts, and lower shock mounts. you can use the 3/4 front springs, steering box and pitman arm. the rear frames are straight so you can shorten them to 1/2 ton wheelbase ez. check out my website the 54 with a 250 motor was a 3/4 ton long bed
1949 SUBURBAN
If you're close to the Terre Haute area, try Elliot and Sons in Tecumseh. They're about 6 miles north of Terre Haute on 63. very large yard and heavy on older iron. I don't recall seeing any 1/2 ton ADs the last time I was there, but there could be one back there. Be prepared to clim, though, as most of the good stuff (read old) is up at the top of the hill. Nice loooong climb, too.
Bill Burmeister
