4 members (Otto Skorzeny, Philipj, 60steve, Greg '46), 67 guests, and 4 robots.
Topics128,181
Posts1,057,151
Members48,464
Hey guys I'm looking for your help again. When I brought this truck home the carrier was trash, so I finally got it out and can't seem to figure out how to get it off. I don't even know if this is the original shaft or not- it's a '49 3/4 ton. Here is a pic of it so you can tell me what ya think.
http://i245.photobucket.com/albums/gg53/sapo_trucker/P2170660.jpg
http://i245.photobucket.com/albums/gg53/sapo_trucker/P2170662.jpg
http://i245.photobucket.com/albums/gg53/sapo_trucker/P2170661.jpg
Here also are some pics of the 4 speed floor shift tranny that's in it (note the custom made crossmemeber!) I would like to see if anyone can tell me the model # or if it's even the original tranny. The truck now has a 250 inline in it. Or where I can find the # on the tranny. Thanks again guys!
Jeremy
http://i245.photobucket.com/albums/gg53/sapo_trucker/P2170668.jpg
http://i245.photobucket.com/albums/gg53/sapo_trucker/P2170667.jpg
http://i245.photobucket.com/albums/gg53/sapo_trucker/P2170669.jpg
On the yoke end there is a cotter pin that will need to be removed and then you can remove the nut and the yoke should slide off letting the carrier assembly slip off the drive shaft. Hope that helps.
That trannys an SM420. The casting numbers should be on the drivers side near the rear above the PTO cover if I remember right. That would be an original type tranny for that truck.
Jeff
My 1953 Chevrolet
1947.1 Gallery
ok thanks very much! That tranny would not have come out of the same vehicle as the 250 motor did?
SM420 is the correct 4-speed for a '49 but also could have been original in a '63 to '67 where that motor might have been found.
Just out of curiosity: that is probably not a very freeway freindly tranny is it? So what are my options as far as swapping this for a more streetable tranny- mainly manuals that will bolt up to my inline 250. I have a t350 out of a '78 pickup but not sure if it's any good and not sure if I want a automatic in there or not, but will it bolt up? Thanks for the help guys!
The SM420 transmission is a heavy-duty 4-speed truck transmission with a 1:1 4th gear - direct drive. The 49 rear end will have a 4.57:1 ratio. So you are correct that combination is not very freeway friendly. It really depends on what you want to do with the truck. Do you want to pull/tow/haul heavy loads or cruise at 65 under a light load? There have been dozens of threads about T-5 trans swaps into this model/style truck. Search this site and the inliners.org site. But T-5's are not heavy-duty......
For help with the carrier bearing go to the links section of this site and look for Keith Hardy's site chevy.tocmp.com for online Chevy truck shop manuals. Good luck!!
Professional Novice
The 350 Auto will bolt up to your 250 engine but you need to consider transmission mounts, cooler & lines, shifter, and of course driveshaft mods. It will not however improve your freeway speeds as it like all non overdrive transmissions are 1:1 in high gear. As Frank mentioned the T-5 is a good option and there are a number of other overdrive options all of which require some modifications to various components and sometimes a substantial cash outlay.
Fred
I do plan to use this as a cruising truck and not put it to work. The rear has been swapped but I don't know the ratio it has but knowing who had it, it is probably low. What vehicles had the T-5 tranny? I plan to swap the rear anyway so maybe I'll just see how it runs after that before swapping the tranny. I don't plan to take many trips but I would like to know I could when I choose to. I didn't think about the cooler lines and the other junk that goes with the t350 either so that's out the window. Thanks for the help guys!
The original setup did not use a mount on the transmission. The rear mounts were on the bell housing and the transmission hung off the end. I would think that your bearing troubles probably started there. You probably will want to replace the transmission and probably the rearend with an open driveline. The other approach would be to go back to an older style engine like a 235. I think that you may have a lash up there that will never work properly.
1951 1 Ton Completed
I was concerned about the same thing when I saw the picture of the home-made crossmember under the tranny and those angle brackets going down to the original bellhousing crossmember. Looked unstable to me. Good luck with it.
Professional Novice
well on closer inspection the bearing is in great shape, it's the rubber that goes between the bearing and the bracket thats missing that I need to find. What do you think he put the angled brackets on the bellhousing for? Would the extra crossmember really hurt more than help? Last q for today is where is the slip yoke (I think that's what you call it) to where the axle will extend and retract over terrain, heavy loads, etc.
