1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37687 10/03/2003 1:21 AM | Joined: Oct 2003 Posts: 2 Junior Member | | Junior Member Joined: Oct 2003 Posts: 2 | I'm at the very first stages of trying to turn my 1946 ck pickup into a daily driver. I'm going to end up going with a new engine, because the old inline has had the heads removed for several years, out in the weather, and the rust is rampant in the cylinders. However, in an attempt to learn more about my truck, I tried to identify the block casting number. The number engraved next to the distributor hole on the block is "LASI00493". I have already checked at inliners.org, and found similar letter pre-fixes, but not a match. Am I looking at the wrong number, or do I just have an oddity or rarity? Any help would be much appreciated. Thanks! Raymond Fowler
Rookie with a great ambition..... 1946 Chevrolet 1/2 ton pickup on the road.
#37688 10/03/2003 2:35 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | What you found is the serial number. To properly id the block, there is a casting number aft of that by the starter. It might be behind the starter. It should be a 6 to 8 digit number that sticks out of the casting. Go to www.inliners.org under casting #s to decode it.
Fred 52 3600 69 C-10
#37689 10/03/2003 3:10 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Was the LAS number stamped on the flat spot next to the distributor? Could the LASI.... be LAS1....? I have a 235 with an LAQ number stamped there. (L hints '53) I think Ken and BigGreen48 have LAQ stamped engines. I finally found my casting number (3701481) under a ridge in front of the fuel pump. Never would have found it while the engine was in the truck. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
