6 members (Shaffer's1950, Stovebolt48, Eisenholtz, Hotrod Lincoln, 2 invisible), 53 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#37687 10/03/2003 1:21 AM
Junior Member
Junior Member
I'm at the very first stages of trying to turn my 1946 ck pickup into a daily driver. I'm going to end up going with a new engine, because the old inline has had the heads removed for several years, out in the weather, and the rust is rampant in the cylinders. However, in an attempt to learn more about my truck, I tried to identify the block casting number. The number engraved next to the distributor hole on the block is "LASI00493". I have already checked at inliners.org, and found similar letter pre-fixes, but not a match. Am I looking at the wrong number, or do I just have an oddity or rarity? Any help would be much appreciated.
Thanks! Raymond Fowler
Rookie with a great ambition..... 1946 Chevrolet 1/2 ton pickup on the road.
#37688 10/03/2003 2:35 AM
What you found is the serial number. To properly id the block, there is a casting number aft of that by the starter. It might be behind the starter. It should be a 6 to 8 digit number that sticks out of the casting. Go to www.inliners.org under casting #s to decode it.
Fred
52 3600
69 C-10
#37689 10/03/2003 3:10 AM
Was the LAS number stamped on the flat spot next to the distributor? Could the LASI.... be LAS1....? I have a 235 with an LAQ number stamped there. (L hints '53) I think Ken and BigGreen48 have LAQ stamped engines. I finally found my casting number (3701481) under a ridge in front of the fuel pump. Never would have found it while the engine was in the truck.
