1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | My 283 V8 will be rebuilt professionally this summer. My wiring looks almost all original and is in pretty bad condition. I will sacrifice stock appearance when it comes to some electronics. I'm considering an HEI distributor but I'm not sure about type of alternator and whether to include original type voltage regulator on firewall, and such details. If you were starting this from scratch, and wanted reliability above all, what kind of set-up would you choose? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree with 2many. The factory type HEI dist doesn,t clear the firewall on that model if you have the engine in the original position. You can use an aftermarket electronic dist or put a conversion kit in the original. I use the Crane conversion kit. It is easy to install & not expensive. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Really good advice coming at you. I've just installed a Pertronix unit on my 230. Most of the aftermarket wiring set ups are very well identified as to where they go, and with some patience, you should be able to get it done without putting a fire to the shop with the truck inside(intentionally). The weakest part of most all these old trucks is the electronics, so anything you can do to ugrade them is money in the bank. | | |
