| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37648 06/18/2004 1:47 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Does anyone have a good picture of how & where the throttle cable should be hooked up to the carb and/or linkage? If not, a good description would help. My is disconnected and I would like to fix it.
There is a bracket on the carb that has two hold-down screws; one for a cable to hook to the carb for the choke. I assume the other, which makes the cable face downward is for the throttle. The only place I can find that it might hook up to is the throttle linkage that hooks to the carb but the tab is about 12" lower than the carb. I believe this would cause it to interview with the pedal inside the cab.
Any help is appreciate! | | |
#37649 06/18/2004 2:42 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I'll look for a photo but maybe I can explain how I did mine.
The vertical throttle linkage from the block to the carb has a right angle bend at the top. The short piece of the bend goes through the carb throttle lever. It has a hole at the end and was held in place with cotter pin when I got my truck. I put my throttle cable through that hole and put a cable clamp on the end of the cable. You also have to clamp the outer part of the throttle cable vertically pointing down.
Yep, a picture would be worth all those words! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#37650 06/18/2004 2:59 PM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Michael -
I just sent you an e-mail with two pics I found on the board.
Hope they help!
Dave | | |
