4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
#376404 02/17/2008 5:24 AM
51 Chevy 3/4 ton. My cab and bed are off and will be ready to put back on in two or three weeks (fingers crossed) and most everything I can do at this point is done except the brake booster vacuum line. I don't want to just run a rubber hose. Is there a "cooler" hook up than a rubber hose for this? ohwell
http://good-times.webshots.com/photo/2933329710099708909JKYdtC
~Jim
Apprentice
Apprentice
you can use the stainless wrapped rubber for a little better look, or even some aluminum or steel line bent to how you like it with a small rubber piece at each end.
