| | | Forums66 Topics128,094 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 51 Chevy 3/4 ton. My cab and bed are off and will be ready to put back on in two or three weeks (fingers crossed) and most everything I can do at this point is done except the brake booster vacuum line. I don't want to just run a rubber hose. Is there a "cooler" hook up than a rubber hose for this? http://good-times.webshots.com/photo/2933329710099708909JKYdtC
~Jim
| | | | | Joined: Dec 2007 Posts: 34 Apprentice | | Apprentice Joined: Dec 2007 Posts: 34 | you can use the stainless wrapped rubber for a little better look, or even some aluminum or steel line bent to how you like it with a small rubber piece at each end. | | |
