0 members (),
125
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 20 Apprentice | | Apprentice Joined: Sep 2007 Posts: 20 | Hello All, I currently have a column shift for my speed with overdirve in my 1964 burb. The linkage isn't working well at all.I am stranded in my driveway once again, with the tranny stuck in 3rd and the shifter and linkages way off in some alternate pattern related to the coming of the solstace and not shifting gears.This is the 4th time this has happened to me - last time required a rebuild of some tranny bits and the linkage rod I broke. So enough whinning ...
I am wondering if anyone knows which hurst shifter will work with the 3 speed trans (Saginaw 3sp with 7 bolt side cover 66-72?). My major concern is the overdrive solenoid,and whether it will get in the way of the shifter. Does anyone have and experience with these set ups and/or dimensions for the shifter linkages in relationship to the trans.
Thanks in advance. Bert.
Bert 1964 Chev Suburban
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Here's how I did it. This is a home made bracket I made. This places the shifter in the middle of the floor. It isn't pretty but I'm a daily driver and this set-ups been good for over 40 grand miles. Yours will be easier with the Saginaw. I wouldn't give up on your column shift though. Inspect each joint for allignment and play. You can improve on these joints by installing articulating ball joints, you'll then have no end play and everything will remain alligned. It is frustrating though...I've vowed to go back to the column shift myself but only after I install my 7 bolt side cover Saginaw I will be rebuilding this spring.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I adapted a Hurst to a 7 bolt Sag. years ago. You have to do a bit of modification to the mounting bracket and re-shape the shifting rods but it will work fine, mine did. I will soon be doing the same to my '54 GMC and expect no problem with it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I adapted a Hurst to a Saginaw 4-speed with the overdrive. It worked.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
