1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I have a 1951 Chevy 3100 short bed and it's a little snowy out there in Ct. to get under the truck. Here is what I would like to address first. The parking brake pedal goes right to the floor. I ordered a parking brake cable and it is on the way but I was wondering if any one out there has encountered this and what are the common causes for the brake to act like that. I have also order a choke and a throttle cable. The engine turns but won't kick over. Both cables are dangling. I thought I would have my wife start it while I pulled the carb choke open. What would you guys do? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | ??? There are 2 parking brake cables on your truck as well as a rod with adjustment. It's also possible that your shoes are just worn out. I would dig deeper before buying parts and do more research before trying to start it so as not to bend a pushrod, break a ring or do other damage. Fresh fuel, new plugs, point gap, etc. are other things to make sure of. I see the online shop manuals are down so I would suggest you buy one.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Could be parking brake is disconnected, or broken cable
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Put on some really warm clothes and crawl under before you blow the kids inheritance buying parts you won't need. BTW if you need parts I have a few extra I bought and don't need. Also DON'T try to start it before going through the proper procedures.
~Jim
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Ahhh, the old parking-brake-doesn't-work problem. When I bought mine it didn't have a parking brake so I decided to get the parts and install one. Well, one thing led to another and now, thousands of dollars later, I'm about to do a frame off re-build of my truck. Watch out, it could happen to you.  | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Ahhh, the old parking-brake-doesn't-work problem. When I bought mine it didn't have a parking brake so I decided to get the parts and install one. Well, one thing led to another and now, thousands of dollars later, I'm about to do a frame off re-build of my truck. Watch out, it could happen to you.  OMG !! You too !!! I thought I was the only one that spend over $15,000 for a set of brakes !  Man... I feel much better now  Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Yea, I used to make fun of people with boats... you know - "a hole in the water you pour money into"? Well, now the shoe's on the other foot.
Two steps to restore a vehicle: STEP 1 - Empty the ashtray STEP 2 - Empty your bank account
:mad: | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | I thought my wife was going to choke the last time I told her what I had spent 'so far'. Guess she thought I could do everything for a few hundred bucks. I told her it is like the decorating she does in the house where small things add up over a period of time. If that doesn't work, I just start talking about getting a motorcycle. Works almost every time! | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Czechman, there are a few more steps:
STEP 3 - Empty your veins. (There are always sharp edges there to gouge you.)
STEP 4 - Empty your brain. (No matter how smart you thought you were, the truck will make a bumbling idiot out of you.) | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Is that because the people at GM created a truck 50 years ago that was smarter than Einstein? | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Also, Curt, the manuals page is back up. | | |
