4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#374046 02/11/2008 11:45 PM
The PO of Ol Yeller installed a 12 volt system. The alternator drive pulley doesn't quite line up with the other pulleys so I yanked off the belt and alternator to find a homemade bracket that has more metal than a WWII battle tank. And no way to adjust the fore and aft alignment. Is there an after-market or generic alternator mount bracket available? Will the new one (if available) adjust for the alignment of the belt path? Or should I get creative and build a smaller and smarter battle tank?
tangovino,
I'm not up to speed on the battle tanks, but if you find a bracket that might fit, it's pretty simple to use washers (SAE) to stack either in front of or behind the mounting lug on the alternator. This moves it forward or backward the thickness of a washer for alignment purposes. The total stack is tight enough that when the long bolt is tightened the whole assembly is snug.
This same thing is done using nice turned spacers, but the stacked washer deal isn't totally hokum! smile
Stuart
automarc:
Well, I tried the washer routine but the homemade braket prevents me from moving the alternator further forward. I'll keep looking for a better bracket. Thanks for the heads up though.
Mitch
Mitch,
If you have some extra dough and want a first class bolt on bracket, check out this link.
http://www.merchantamerica.com/chevyhotrod6/index.php?ba=view_category&category=6237
Stuart
Stuart:
Thanks for the info. I'll give them a call as I can't really see exactly what I need.
Mitch
(Years ago I did a lot of salmon fishing out of Arcata)
A lot of people reuse the old generator bracket, me included. I simply elongated the holes in the bracket with an end mill in the drill press so it slides fore and aft.
Paint & Body Shop moderator
Well, therein lies my problem, I'll have to find a drill press. That will work, enlongating the holes, it's just that this piece of metal the PO used is about 7/8's inch thick. I may just fabricate one using a piece of scrap that is thinner. Thanks for all the suggestions. (Now if I can only convince the wife I need a drill press for Valentines Day).
The bracket is available from Patrick's in AZ.
www.patricksantiquecars.com
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dave: Thanks! I have to call then regarding some other things too, and now it's a 'one call does it all'.
Ex Hall Monitor
Ex Hall Monitor
Quality Power sells a universal bracket that will fit all stovebolt sixes.
Dave: I called Patrick's and 2 days later I had my bracket. Phillip was very knowlegeable and knew just what I was looking for. Thanks for the heads up.
Mitch
Hey guys and gals:
I just installed Patrick's alternator bracket. I had to grind a hair off the inside of the mount for the alternator to fit. Their paint was too thick. It all works like a charm.
Thanks ya'all!
