0 members (),
83
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Hey,
I need to take the driver side window out of my truck. I know that I need to take the vent window out first, but how exaclty is that done? I just need to replace the glass on the driver side. I can't see any screws or anything, but I know that they must be there. Thanks for the help in advance.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | Kyle, it's been a while since I pulled one out, but I'll try to remember the best I can. The whole vent window post and window track have to come out as one piece. I think there are 3 or 4 screws around the outside of the door that hold the top of the vent window frame in place, and then one or two bolts behind the door panel that hold the bottom of the window track. I can't recall for sure, but you may have to loosen the rear track as well. Then with the window down, the whole vent window frame, post and track should lift out the top. Hope that helps.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Thanks Truck Nut I am gonna go and work on it this weekend so I will tell you what I find. Thanks again!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | Kyle, you're very welcome. I just hope I was pretty close with my instructions, like I said it's been years since I took one out. I wanted to go out and look at one of my old trucks last night to refresh my memory but I got home too late. Best of luck.
TruckNut
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | TruckNut , set ya on the cource ...just follow his tips you will make it OUT ALIVE ! ...lol What he said ..renmove the retainin screws around the perimeter of the vent window , down low there is 1 bolt holding the long arm in place , have the window DOWN an the vent window will kickk back to the 30 degree position an pull it up an out. | | |
