9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I looked in the search area but came up with nothing. Any good way to remove old tar from my white bumper I tried a few things but to no avail any trick chemicals out there..Peter | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Kerosene. Lacquer thinner. Single edge razor blade(gently) And.....good 'ol W-D 40. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There are many tar removers on the shelf of your area flaps or as delux54panel stated above.
Tony Smith
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Mineral spirits or Grease and Wax Remover... I wouldn't go near any painted surface with lacquer thinner. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I've always used good ole 87 octane with good results; and stay off those hot tarred streets.
~Jim
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Peter,
Gasoline is the most hazardous material that the average person comes in contact with. It's flammable but more significantly, it's explosive. This is winter and your risk is much greater when using gasoline in a closed space.
Gasoline is NOT a good choice for cleaning anything... ever... under any circumstances. There are alternatives that work just as well that won't incinerate you in the process. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Bug & Tar remover and a Mr. Clean Magic Eraser !!! ...will have your bumper like new. And No scratches !!! | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I've been taught "like dissolves like." Althought this doesn't mean to wipe it down with tar, or that there aren't other/better solutions, I'd first start with an oil-based product like 30wt, WD40, 3-in-1, etc. (I was less than impressed with Bug & Tar remover for removing love bugs. WD40 worked better in my situation.)
Mr. Clean Magic Eraser- I never thought of that! It work well?
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | All I AM GONNA SAY on the Mr. clean Magic Eraser is to give it a try !...you will be impressed ! Now dont get the off the wall brand that says it is the same thing ...they are not. I use them all the time on my BASS boat also an love em . for a few $ give em a try ...you will like em . | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | This is hard tar... I tried the wd 40 and octane 87 nothing I think I may have to use steel wool and repaint the bumper... I'll try the eraser next.. Peter | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | With care, I bet heat could be a help.
Bill | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | its mainly spots of tar.... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I always assume people here to be adults and not boneheads when it comes to dangerous flammables such as petroleum distillates. If you don't know the dangers of gasoline raise your hand. I have been using these products for almost 60 years and don't believe anyone on this forum to be uninformed. I think it wise to warn all youth of the potential dangers with gasoline, I don't however believe that warning is due those here.
~Jim
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | heat gun, got one from Northern Tool, Harbor Fright has them too.. about $10 ... and it does produce some heat!
Mike | | |
