6 members (FishinToms53, Gdads51, Woodcmiami, TUTS 59, amtrakjoe, Otto Skorzeny), 140 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#374567 02/13/2008 1:38 AM
I looked in the search area but came up with nothing. Any good way to remove old tar from my white bumper I tried a few things but to no avail any trick chemicals out there..Peter
Kerosene. Lacquer thinner. Single edge razor blade(gently) And.....good 'ol W-D 40.
delux54panel #374589 02/13/2008 2:29 AM
There are many tar removers on the shelf of your area flaps or as delux54panel stated above.
Tony Smith
Mineral spirits or Grease and Wax Remover... I wouldn't go near any painted surface with lacquer thinner.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #374658 02/13/2008 4:23 AM
I've always used good ole 87 octane with good results; and stay off those hot tarred streets.
~Jim
Peter,
Gasoline is the most hazardous material that the average person comes in contact with. It's flammable but more significantly, it's explosive. This is winter and your risk is much greater when using gasoline in a closed space.
Gasoline is NOT a good choice for cleaning anything... ever... under any circumstances. There are alternatives that work just as well that won't incinerate you in the process.
Woody
Door Art Collection
Czechman #374775 02/13/2008 2:15 PM
Bug & Tar remover and a Mr. Clean Magic Eraser !!! ...will have your bumper like new.
And No scratches !!!
1952 Chevy Shortbed
Photos in Photobucket
#374797 02/13/2008 3:01 PM
I've been taught "like dissolves like." Althought this doesn't mean to wipe it down with tar, or that there aren't other/better solutions, I'd first start with an oil-based product like 30wt, WD40, 3-in-1, etc. (I was less than impressed with Bug & Tar remover for removing love bugs. WD40 worked better in my situation.)
Mr. Clean Magic Eraser- I never thought of that! It work well?
TxLaTx #374815 02/13/2008 3:28 PM
All I AM GONNA SAY on the Mr. clean Magic Eraser is to give it a try !...you will be impressed !
Now dont get the off the wall brand that says it is the same thing ...they are not.
I use them all the time on my BASS boat also an love em .
for a few $ give em a try ...you will like em .
1952 Chevy Shortbed
SW_Radial #375072 02/14/2008 1:32 AM
This is hard tar... I tried the wd 40 and octane 87 nothing I think I may have to use steel wool and repaint the bumper... I'll try the eraser next.. Peter
With care, I bet heat could be a help.
TxLaTx #375731 02/15/2008 5:39 PM
its mainly spots of tar....
I always assume people here to be adults and not boneheads when it comes to dangerous flammables such as petroleum distillates. If you don't know the dangers of gasoline raise your hand. I have been using these products for almost 60 years and don't believe anyone on this forum to be uninformed. I think it wise to warn all youth of the potential dangers with gasoline, I don't however believe that warning is due those here.
~Jim
heat gun, got one from Northern Tool, Harbor Fright has them too.. about $10 ... and it does produce some heat!
Mike
