| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 4 New Guy | | New Guy Joined: Feb 2008 Posts: 4 | i have a 63 gmc 1/2 ton i want to convert to disc brakes. i have a chance to get a 86 1/2 ton chevy pickup that i would like to get the parts off to do it. has anybody here done this swap? i've been told i have to use the 86 balljoints in the 63 control arms to use the newer spindles. i was thinking i could also get the power booster and master off the doner truck too. maybe even the steering column. any help would be greatly appreciated! THANKS! | | | | | Joined: Jul 2006 Posts: 6 New Guy | | New Guy Joined: Jul 2006 Posts: 6 | Hello iloveoldstuff I have a 65 that we put the 86 disk brakes on. We used the whole k member and every thing (a arms, spindles, ball joints) to get ride of the grease able bushings. The 86 k member for the most part bolts right up. We only had to elongate 4 holes to make it fit to the frame. We left ours manual brakes. Hope this helps | | | | | Joined: Feb 2008 Posts: 4 New Guy | | New Guy Joined: Feb 2008 Posts: 4 | thanks for the reply. i've heard of this before but sounds like alot of work. how long did it take you to do?
you can never have too many vehicles!
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | get your tape measure out, it's simpler than you think and a very nice upgrade. pull the newer k-member and you will see how close it comes. their is probably some info on 67-72 chevytrucks.com like pic's.good luck. | | | | | Joined: Feb 2008 Posts: 4 New Guy | | New Guy Joined: Feb 2008 Posts: 4 | thanks for the info. i'll be checking it out. does'nt look like i will be too hard, especially with air tools! thanks again!
