4 members (52Carl, MRMEROTH11, Otto Skorzeny, fonz8261), 101 guests, and 2 robots.
Topics128,052
Posts1,055,771
#373957 02/11/2008 9:11 PM
Here's a pic from an ebay truck. What is that thing in between the oil filter and the distributor.
If its the oil filler tube, then what engine is this? My oil filler is on top of the valve cover.
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #373958 02/11/2008 9:13 PM
I see a coil and a dipstick. Which one were you referring to??
~Jenny
"Custom can't be bought. It's achieved one cut at a time."
1950 Chevrolet 3100 1/2-Ton
That's the oil fill tube with a screen in the can part to keep junk out of the crankcase..Also noted that valve cover uses 2 studs for hold down..Think you should e-mail the seller and find out what engine it is...possibly a GMC...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Stick #373995 02/11/2008 10:09 PM
Is it a road draft tube/ oil filler combo? Its in the road draft tube location, and has the oil filler cap on top of it.
66stepside #374004 02/11/2008 10:25 PM
That looks like a jimmy engine alright, and the tube is the crankcase ventilation tube (oil filler and road draft tube) with the oil bath filter element inside the little tub at the top.
My 1953 Chevrolet
1947.1 Gallery
Its a GMC engine, alright, and I'll go with rustednuts on the road draft tube and filler. GMC engines originally had the size stamped on the serial number pad by the distributor- 228, 248, 270, 302, etc. I think the size is the first three numbers in the serial number on that pad- if the numbers haven't been ground off.
Harvester
Could it be an early PVC system? it kind of looks to me to have some sort of line coming off it going around the front of the engine.
Also, it's kind of hard to see clearly from the crud, but you can make out GMC on the rocker.
Bill Burmeister
No it's not PVC, but it is PCV.
Picture 1 from oldgmctrucks.com
Picture 2 from oldgmctrucks.com
UH OH, the links only work if you are registered at that forum. I'll try to find public links to replace them.
OK, I scanned a pic from the maintenance manual and uploaded it to my site. GMC crankcase vent
Cletis #374193 02/12/2008 4:54 AM
Ooops. Typo.
Won't let me see the links.
Bill Burmeister
Gotcha! dance
Cletis #374198 02/12/2008 5:05 AM
Well it looks like another distributor with out the cap. But what do I know I only sold auto parts for 12 years.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Check the new link in my above post.
