| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37406 01/19/2005 12:15 AM | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | I have read many of the post about add on filters & the need for restrictors or by pass systems ect. What I am wondering is how many 235 owners just leave the oil holes plugged as apparently they were originally & why not ?
Thanks, Kelly 53 3100 | | |
#37407 01/20/2005 4:43 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | i do not have an oil filter on my 235. just try to change the oil when it starts getting dirty. motor is out of a 62 chevy pickup and did not have a filter when i got it and my original motor that i replaced did not have one either. i believe they were considered an option in 54.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#37408 01/20/2005 6:47 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | guess it would be better to have one but as the like the other Tx remarks I do not have one in my 52 with the 54/235,,,driven the past 8 yrs with out trouble(Knock on wood) Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#37409 01/22/2005 3:31 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Have a spin on conversion/modification on one of my 235s and a cartridge drop in type on the other. For the amount of oil I am told they filter, I could live without them. One problem I have is determining how much oil to put in the crankcase with the filter. Calls for 5 quarts in the original manual but how much more do I need for the filter, surely not a quart. And is it best to put all of the oil, filter oil included, into the crankcase or put oil in the filter until it tops and then put the 5 quarts in the crankcase. I have been putting the whole amount in the crankcase and getting oil leaks at both ends of the block, because I presume only a small amount of oil is going to the filter and my oil pan is over full. | | |
#37410 01/23/2005 10:54 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | @ oldblue put 5 quarts in the crankcase and drive it around the block. Then check the dip stick and refill. That`s all Frank | | |
#37411 01/25/2005 6:48 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I just toss a roll of toilet paper in the canister and don't worry about it.
delete my account and pictures
#37412 01/26/2005 1:01 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | After adding my two cents to this forum I started to wonder what would really happen if I disconnected the filter and put threaded brass fittings in the holes. I have an after market unit with the mount which takes a spin on filter. I change my oil every 1000 miles and as my filter plumbing is another source for drips I am considering removing it entirely. Wonder if it would hurt the oil flow or pressure. | | |
#37413 01/28/2005 6:45 AM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | No , you won't hurt it from a pressure stand point but a filter , _any_filter is better than no filter .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
