8 members (Tronman, Lightholder's Dad, LAROKE, Stovebolt48, tclederman, Hotrod Lincoln, carbking, 1 invisible),
99
Mod | | | Forums66 Topics128,042 Posts1,055,511 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 33 Apprentice | | Apprentice Joined: Jan 2008 Posts: 33 | I've got a 63 C60 and I was wondering if any of them came with arm rests on the door panel. If not did they come on the half ton versions and how hard would it be to attach one to the door of the bigger truck? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Arm rest were an option..all of the doors are set up for them behind the panel...you have to drill the panel for the bolts to mate up with the threaded inserts in the door...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | They were an option on PU's but I don't think they were available on the larger trucks. However they could be installed since the steel panels were the same. | | |
