2 members (klhansen, Samantha),
51
Mod | | | Forums66 Topics128,053 Posts1,055,778 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Here's a pic from an ebay truck. What is that thing in between the oil filter and the distributor. If its the oil filler tube, then what engine is this? My oil filler is on top of the valve cover.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Oct 2007 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 94 | I see a coil and a dipstick. Which one were you referring to?? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | That's the oil fill tube with a screen in the can part to keep junk out of the crankcase..Also noted that valve cover uses 2 studs for hold down..Think you should e-mail the seller and find out what engine it is...possibly a GMC...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Is it a road draft tube/ oil filler combo? Its in the road draft tube location, and has the oil filler cap on top of it. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | That looks like a jimmy engine alright, and the tube is the crankcase ventilation tube (oil filler and road draft tube) with the oil bath filter element inside the little tub at the top. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Its a GMC engine, alright, and I'll go with rustednuts on the road draft tube and filler. GMC engines originally had the size stamped on the serial number pad by the distributor- 228, 248, 270, 302, etc. I think the size is the first three numbers in the serial number on that pad- if the numbers haven't been ground off.
Harvester | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Could it be an early PVC system? it kind of looks to me to have some sort of line coming off it going around the front of the engine. Also, it's kind of hard to see clearly from the crud, but you can make out GMC on the rocker.
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No it's not PVC, but it is PCV. Picture 1 from oldgmctrucks.com Picture 2 from oldgmctrucks.com UH OH, the links only work if you are registered at that forum. I'll try to find public links to replace them. OK, I scanned a pic from the maintenance manual and uploaded it to my site. GMC crankcase vent
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ooops. Typo. Won't let me see the links.
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Gotcha!  | | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | Well it looks like another distributor with out the cap. But what do I know I only sold auto parts for 12 years.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Check the new link in my above post. | | |
