0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 28 Apprentice | | Apprentice Joined: May 2005 Posts: 28 | I need advice and help agian on probable factory colors under the hood on 1954 Chevrolet 3100 1/2 tons. I'm pretty sure firewall is body color, but what about inner fenders, under hood, hood latch plate, etc. Any and all help is greatl;y appreciated. Also if anyone has photos of the pin stripe around beltline, height above groove, width, etc., as well as wheel stripes and locations, would be appreciated also. Body color will be Mariner Blue with Pearl Beige Interior. While I'm at it, is there a big difference in Pearl Beige and the Cream Stripe for the beltline? Thanks again for all the great advice and info found in the Stovebolt Forums!!!!!!!! Joe | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey Joe, From my experience you will find the firewall is body color, inner fenders and a lot of engine components are a black but not gloss or flat, it's a low sheen semi flat (Eastwood sells what they call "Underhood Black"). Under side of the hood is also that same black and to be really correct there will be overspray of the body color. The hood latch plate is cad plated, if your talking the big panel which holds the hood latch plate, it is that same black as the inner fenders. I don't believe the '54's had the beltline pinstripe, only wheel stripes.
Bruce
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | My 54 also has black underside of hood with the described light overspray but also written in a black grease pencil in a script handwriting is the word "transport" which I assume matches up to the transport blue exterior color of my truck. | | |
