1 members (CuzzFuzz), 101 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#371390 02/06/2008 8:58 PM
New guy here looks like a great place to be if your into old trucks.....and I am.
Working on 65 c-80 low cab forward and in need of both front brake hoses 9000 lb axle with power steering. anyone have an idea????
1965 chevy c-80 409 5-2 20000 original miles.
1965 chevy c-60 348 5-2 single axle tractor.
1952 chevy p/u 235 4 speed restored.
1965 chevy c-60 couch.
One grouchy wife. FOR SALE....CHEAP!!!!
The future is not what it used to be.....
Have a new pair of metric vise-grips and large metric hammer, can fix anything...
NAPA or any good Flaps if you can still find one. Take them in and match them up. Might also try Wagner on the 'net for sizes.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
3B Offline
Hy Mr Goodwrench, according to my parts book it should be GM 3932098, same hose as the 50 - 60 series that translates into Napa UP36698 $36.49, hope that helps.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Now it can't get any better then this, not only did ya get a part number but a price too.....Joe
Man you guys are great!!!!! thanks so much will check it out tomorrow.
Number and price was good...thanks again guys!! Now one more, steel brake line leaves master cylinder goes down into a short rubber hose and then back to steel (5/16") anyone know where that hose can be had?
3B Offline
Hy Mr Goodwrench, I think the part, hose/pipe you're are looking for is GM 3766274 that translates into Napa UP6100 $19.99, I can't be positive because the parts book doesn't specifically mention the M80 series, go and have a look, if it isn't right, get back to us, hope that helps
Thanks again shop shark!!!! good number but wrong hose, clutch slave cylinder maybe??? The one I need has a 5/16" steel line screwed into both ends,and runs from the master to the hydrovac the number you gave me was for 1/4"
Thanks for your effort!!
3B Offline
Hy Mr Goodwrench, can you tell me how long this hose is? I found to other possibilities, but neither of them cross to Napa numbers
About 4 inches female inverted flare on both ends.
I am flexable on length being I'm bending new steel lines.
24601
Mr. Goodwrench -- Welcome to Stovebolt.com!
Be sure to check out the rest of the site -- use the menu bar at the top of the page. Especially look in our Links Page. You will find lots of links for parts, insurance, clubs, other sites and did I mention parts?? wink
Also check out our Features, Tech Tips and Gallery. A lot of new guy questions can be answered among those pages.
And don't forget the search features of the discussion forums.
But never hesitate to ask questions!
Welcome!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
3B Offline
Hy Mr Goodwrench, I think the hose you're looking for is GM 3883151, that one doesn't cross into the Napa line, my other thought would be to use the Napa UP6100 with a Weatherhead adapter 7917 on each end, check that stuff out at your local Napa and see if that will do the job for you. I checked all my brake hose illustrations and could not find one with 5/16" inverted flare female on each end, I hope the fix I mentioned will do the trick, if not let us know.
Looks like I'm going to use a 1/4" two wire hydraulic hose, male inverted flare on both ends, and two couplings to get back to female. kinda a bogus way to go but I guess whatever works.
