5 members (Rusted Nut, Southerntruck, MickeyP, mick53, Dennys28), 102 guests, and 3 robots.
Topics128,043
Posts1,055,611
#37356 10/03/2002 9:29 PM
Does anyone know which is the correct position of the coil on a 235? Is it upside down(wire connections facing down) or right side up? I have been told by some that they came upside down while others say right side up. thanks-- :confused: slowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
#37357 10/04/2002 12:39 AM
Most of the pictures from factory manuals and sales documents show the coil with the connectors down.
However, many people install the coil upwards because it is easier to make connections (during installation or when timing the ignition) or because they think it will keep the coil from dripping out the fluid it is filled with (PCBs?) or because they like the way it looks or because that is the way they have always seen them installed.
Tim
#37358 10/04/2002 11:48 PM
Tim's right. Factory put them in upside down. Most mechanics would flip them right side up if the removed them, it's easier to put the wires back on.
Fred
52 3600
69 C-10
#37359 10/06/2002 3:46 AM
Anonymous
Unregistered
Anonymous
Unregistered
& its harder for the primary to literally fall out of the coil on hitting a bump.
#37360 10/06/2002 9:50 PM
As above, it was originally pointing down just like it is on the engine in the Revelle put-together model of an Advance Design Chevy. Can't argue with that, right?
