1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37311 04/12/2004 10:12 AM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | I am in the process of re-installing my clutch z-bar and have two questions.
1) Is the part between the arrows in figure 1 missing something? When I pull the bracket out of the z-bar a bunch of crud came out and I don't know if there was some kind of sleeve covering that part.
2) Which way is the bracket mounted to the engine? Like figure 2 or figure 3?
[img]http://home.earthlink.net/~dbvaldez[/img]
Thanx DANO
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#37312 04/12/2004 10:18 AM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Sorry, I tried to post the pictures. The pics can be seen at. web page
#37313 04/12/2004 5:04 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | On the first question I'm not sure, but I think there is a felt washer there to help keep dirt out. Question 2 my Z bar as in figure 3 on my 63. I doubt there is any difference. When it's installed correctly it sits pretty level. If installed wrong it's at a bad angle.
Larry 68 C20 327 daily driver 63 C20 292 Camper truck 65 C10 ? Custom Cab AC,PB,PS,$flasher
I don't own a vehicle that isn't old enough to drink. | | |
