5 members (lc_btv, Leo, FAST55, MickeyP, 1 invisible), 85 guests, and 1 robot.
Topics128,050
Posts1,055,673
#372902 02/09/2008 1:48 PM
my air compressor is set up for 110 or 220 it is wired for 110. is there any advantage to wiring it for 220 or does it not matter
1955 CHEVY 3600 TF
#372958 02/09/2008 4:45 PM
wadd55,
Using the higher of the two available voltages should make the air compressor a little more efficient from an electrical standpoint. Because you 'half' the current draw, you will be able to downsize the wire size and the over current protection, the circuit breaker size.
Stuart
thanks for advice guys, i have 220 right beside compressor i might as well change pigtail and use it. 55 years old and still learning
1955 CHEVY 3600 TF
Good idea,if you have the 220 handy.The only difference is the lower amperage with 220.A lot of people think you get more power and use less power,but this is not true.On my dust collector for my woodshop,when it was hooked to 110,it would trip a breaker everytime it started up. I switched it over to 22o,and no more problems.
Go the 220.
Lower start-up draw from the higher votage and more efficient running.
I run a 5.5 hp 3 phase set-up for the same reason.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
Moderated by  MNSmith
