1 members (CuzzFuzz), 101 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
I have not found one in any of my catalogues. Does anyone know where I can find one or do I have to adapt a PU truck unit? thanks, Ted
All the best, Ted
Ted,
Repair or adapt or find a used one (I've never seen a correct new one for a 54/55 panel body truck).
Or, get an earlier panel-body gas tank and you might be luckier getting a sender for that? Of course, finding any good, used, panel-body gas tank is not that easy.
Tim
hey ted
do you have a sender now, if so what kind of shape is it in? if the top functions fab a float that looks similar. that is what i am attempting to do.
tim is correct,finding a good used tank with a good sending unit attached is like finding the Holy Grail
tom
I don't suffer from insanity, I enjoy every minute of it!
Thanks for the advice. I bought a sending unit for a 54 pickup which is not configured to fit the panel tank. I cut the pickup tube above the float mechanism and used standard compression fittings to reconnect and to turn the unit 180 degrees so that it would fit correctly. I then used my original as a template to bend the pick up tube and float to the correct depth. It worked great and I get a good gauge reading.
Thanks again Tom and Tim
All the best, Ted
Ted
you didn't take any pics of that by any chance? I bet that would be something a lot of people would like to see. Me included
tom
No, no pictures, sorry
I regret that I did not fully document my rebuild. I just get so excited about the work I don't want to stop and take pictures all the time. Maybe next time.
All the best, Ted
Ted,,just the way you explained it,,I can picture it. And with the old one as a template,shouldnt be a problem. Excellent tech tip for future reference!!
