| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | I have not found one in any of my catalogues. Does anyone know where I can find one or do I have to adapt a PU truck unit? thanks, Ted
All the best, Ted
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ted,
Repair or adapt or find a used one (I've never seen a correct new one for a 54/55 panel body truck).
Or, get an earlier panel-body gas tank and you might be luckier getting a sender for that? Of course, finding any good, used, panel-body gas tank is not that easy.
Tim | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | hey ted do you have a sender now, if so what kind of shape is it in? if the top functions fab a float that looks similar. that is what i am attempting to do. tim is correct,finding a good used tank with a good sending unit attached is like finding the Holy Grail tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Thanks for the advice. I bought a sending unit for a 54 pickup which is not configured to fit the panel tank. I cut the pickup tube above the float mechanism and used standard compression fittings to reconnect and to turn the unit 180 degrees so that it would fit correctly. I then used my original as a template to bend the pick up tube and float to the correct depth. It worked great and I get a good gauge reading. Thanks again Tom and Tim
All the best, Ted
| | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | Ted you didn't take any pics of that by any chance? I bet that would be something a lot of people would like to see. Me included tom
| | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | No, no pictures, sorry I regret that I did not fully document my rebuild. I just get so excited about the work I don't want to stop and take pictures all the time. Maybe next time.
All the best, Ted
| | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Ted,,just the way you explained it,,I can picture it. And with the old one as a template,shouldnt be a problem. Excellent tech tip for future reference!! | | |
