Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
The post about cold weather painting got me wondering if I really need to move my compressor out of my garage when I paint?
Could it be a source of ignition or do I want it sucking in and compressing the fumes? The compressor is a craftsman oil less.
Eric
I had mine in the same area I paint in. But moving a 6 hp 80 gallon compressor wasn't an option grin. I didn't have nay problems, just make sure that you ventillate properly. I cracked the door open about a foot or so, then used 3 old furnace blowers (one at the back of the garage, 2 by the door) to blow the fumes out.
BTW- I painted with a BURNING wood stove in the garage for heat. No problems whatoever.
Bill Burmeister
Eric,
I had an oiless Craftsman 60 gallon NON Movable , for a long time and painted with it settin there . NO PROBS..only thing I recommend is that you change the filter after every session as it will suck in the overspray ...and the next day your filter will be clogged and hard as a rock !
I quit buyin the craftsman filters and replaced it with home made ones , I would buy a pack of Scotch Brite pads (for scrubbin dishes) and cut them up for filters that were cheap and disposable.
Just a tip
1952 Chevy Shortbed
Photos in Photobucket
Considering the fact that you're posting makes that a moot point grin
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Well, the vents were shut! grin That day I was only doing some minor painting, not much fumes. For doing anything makor (like a large body panels or cab), having a burning fire is not really a good idea. But m suggestion on using the furnace blowers stans. Can't beat them for moving the fumes out.
Bill Burmeister
Considering that the pressure switch and motor start switch arc I wouldn't paint with a compressor in the same space unless it had an explosion proof motor.
Paint & Body Shop moderator
