3 members (TooMany2count, Rich'sToys, 1 invisible), 74 guests, and 7 robots.
Topics128,021
Posts1,055,354
Members48,420
#37274 10/16/2004 9:20 PM
I've finally found a hei distributor for my 65 292 from a 76 chevy van.This unit has a separate coil and I'm sure I've heard they can be trouble.Should I buy this and give it a try or avoid it and keep looking for one with the coil-in-cap style?? Thanks,Tom.
65 C10 292/700R4 long fleet...Gettin closer by the day.
#37275 10/16/2004 10:42 PM
Riding in the Passing Lane
There is nothing wrong with the separate coil
HEI. I maintained fleets of chevy vans for many
years. Check the advance systems make shure they
are operating properly. Clean the coil & check
for carbon tracks. smile
1972 Chevy c10 Cheyenne Super
#37276 10/17/2004 12:27 AM
Thanks!There's no substitute for experience.Tom
#37277 10/17/2004 12:50 AM
I converted my 292 earlier this year. I wanted an external coil (call me old fashioned) so I went with a '75 setup. It's been working great for me. I just fabricated a bracket for the new coil and installed it in the same spot as the old points coil.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#37278 10/18/2004 2:37 AM
The external coil is preferred by hot rodders, you can run a hotter and more durable coil externally than in the cap.
Fred
52 3600
69 C-10
