0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | New guy here looks like a great place to be if your into old trucks.....and I am. Working on 65 c-80 low cab forward and in need of both front brake hoses 9000 lb axle with power steering. anyone have an idea????
1965 chevy c-80 409 5-2 20000 original miles. 1965 chevy c-60 348 5-2 single axle tractor. 1952 chevy p/u 235 4 speed restored. 1965 chevy c-60 couch. One grouchy wife. FOR SALE....CHEAP!!!! The future is not what it used to be..... Have a new pair of metric vise-grips and large metric hammer, can fix anything...
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | NAPA or any good Flaps if you can still find one. Take them in and match them up. Might also try Wagner on the 'net for sizes. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mr Goodwrench, according to my parts book it should be GM 3932098, same hose as the 50 - 60 series that translates into Napa UP36698 $36.49, hope that helps. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Hy Mr Goodwrench, according to my parts book it should be GM 3932098, same hose as the 50 - 60 series that translates into Napa UP36698 $36.49, hope that helps. Now it can't get any better then this, not only did ya get a part number but a price too.....Joe | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Man you guys are great!!!!! thanks so much will check it out tomorrow.
| | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Number and price was good...thanks again guys!! Now one more, steel brake line leaves master cylinder goes down into a short rubber hose and then back to steel (5/16") anyone know where that hose can be had?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mr Goodwrench, I think the part, hose/pipe you're are looking for is GM 3766274 that translates into Napa UP6100 $19.99, I can't be positive because the parts book doesn't specifically mention the M80 series, go and have a look, if it isn't right, get back to us, hope that helps | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Thanks again shop shark!!!! good number but wrong hose, clutch slave cylinder maybe??? The one I need has a 5/16" steel line screwed into both ends,and runs from the master to the hydrovac the number you gave me was for 1/4" Thanks for your effort!!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mr Goodwrench, can you tell me how long this hose is? I found to other possibilities, but neither of them cross to Napa numbers | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | About 4 inches female inverted flare on both ends. I am flexable on length being I'm bending new steel lines.
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Mr. Goodwrench -- Welcome to Stovebolt.com! Be sure to check out the rest of the site -- use the menu bar at the top of the page. Especially look in our Links Page. You will find lots of links for parts, insurance, clubs, other sites and did I mention parts??  Also check out our Features, Tech Tips and Gallery. A lot of new guy questions can be answered among those pages. And don't forget the search features of the discussion forums. But never hesitate to ask questions! Welcome! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mr Goodwrench, I think the hose you're looking for is GM 3883151, that one doesn't cross into the Napa line, my other thought would be to use the Napa UP6100 with a Weatherhead adapter 7917 on each end, check that stuff out at your local Napa and see if that will do the job for you. I checked all my brake hose illustrations and could not find one with 5/16" inverted flare female on each end, I hope the fix I mentioned will do the trick, if not let us know. | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Looks like I'm going to use a 1/4" two wire hydraulic hose, male inverted flare on both ends, and two couplings to get back to female. kinda a bogus way to go but I guess whatever works.
