7 members (Leo, Goach2, UtahYork, klhansen, JoeDude, pauld, Wayne67vert),
129
Mod | | | Forums66 Topics128,185 Posts1,057,290 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I checked the ZR site and did not see the question directly asked.
If I use zero-rust on the firewall and inner fenders, can I top coat with Rustoluem brand semi-gloss paint?
Jake | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | painting over ZR with Tremclad, the CDN Rustoleum, worked for me
Bill | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | yes or hemeright is veven better | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I've used Zero-Rust and top coated with Rustoleum for frame work. I found that if I top coated with Rustoleum within a day all worked well but if I waited more than a day I got a reaction with the Rustoleum over Zero-rust. The paint crinkled in areas.
| | | | | | Houston54 Unregistered | | Houston54 Unregistered | Jake, for that application I would apply the ZR Crystal coat over the ZR base coat to get a great shine and UV protection. If you are going with a different color though I am sure the rustoleum will hold but I would spray it with a gun to get uniform coverage. | | |
