1 members (dt235sd), 101 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#37112 08/22/2003 1:38 PM
I AM LOOKING FOR SOME WHEELS FOR MY 53 1/2 TON, AND FOUND A WEBSITE NEWSTALGIA WHEELS AND THEY HAD WHAT LOOKED LIKE THE WHEELS I NEED. BUT I AM UNSURE OF THE SIZE AND IF THE STOCK HUB CAPS I HAVE WILL FIT IN THEM? HAS ANYONE BOUGHT FROM THEM, AND PUT THE STOCK HUB CAPS ON?
ANY FEEDBACK WOULD BE GREAT.
THANKS
#37113 08/23/2003 2:38 AM
We had a thread on this a while back and I posted quite a bit of info on this issue, including pictures. Do a search and you'll turn that info up. Talk to Newstalgia and with the year and make, I'm sure they'll be able to tell you the appropriate offset for the type wheel you select. I'm pretty sure you'll not get any new wheels that will take your original hubcaps unless they are modified, but Newstalgia may do that for you.
#37114 08/23/2003 3:11 AM
I was talking to someone at the local friday cruise about wheels and he told me to contact stockton wheel about rims to use the original hubcaps,he said some other rim manufactures make their rims to fit their hubcaps only. I am going to be in the same situation soon,I am planning on a front and rear suspension change on my 37 and would like to find new rims to use the 170 dollar repop hubcaps I have on it now. I am going to find their website and inquire about the rims the have. grin
#37115 08/27/2003 3:18 AM
Junior Member
Junior Member
If you want different/modern rims on you AD truck and still want to use stock hub caps, I have found that you have two choices. They are: (1) remove the center of the stock rim and have a wheel company place it in a modern rim to create a remanufactured rim, which will then fit over disc brakes and large brake drums (2) order a modern rim to the width of your choice and use a hub cap adapter to mount the original hub cap to the new rim.
The Early Wheel Co.(805/688-1187)at www.earlywheel.com offers both of these options. Their hub cap adapter is a metal ring, which is spot welded to the original or repro hub cap. This ring will then snap into the "bumps", which are inside the center of the modern rim. Early Wheel will spot weld the adapters for you or you can purchase them and do the work yourself. Note: These adapters will not work on rims that have "bumps" on the outside of the center of the rim, such as on stock Chevy rims.
This topic was overed in part by an earlier post by Texaholic200, and he referred me to the Early Wheel Co. where I obtained some of the above information. I thank him for his assistance in this matter.
#37116 08/28/2003 12:54 PM
MacDaddy - Eliot Auto Parts in Eliot Maine has quite a few original rims for your truck if you are running the original caps and tires.
The pictures I put up of my junket there yesterday shows Bill standing next a '54 Chev pickup with still had all four original rims (with tires and holding air).
FYI - Kook
