8 members (mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, homer52, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | I was talking to a gentelman the other day that has a 59' GMC. I asked him what engine is in it and he said it was a "GM diesel, the same as a Detroit Diesel". So what did he mean, are they the same? I need some diesel learnin. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | They are the same. There is a lot of written history out there on it that can explain it better, but in the old days they were listed as "GM Diesels" and I believe that it was sometime in the '60's that the outfit became it's own separate corporation and from then on it was known as the "Detroit Diesel".
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | True, same engines, just updated the name from GM Diesel to Detroit Diesel at some point.
Most people, even those who understand the difference, just refer to any of the two cycle GM/Detroit Diesels built from about 1938 on as "Detroit Diesels". Although technically the old ones are GM Diesels.
Grigg | | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 95 | The GM light-truck 6.2L and 6.5L diesel engines were optional in the 1982-2000 C/K series pickup trucks, and in the Suburban, Chevy Tahoe & Blazer, GMC Yukon & Jimmy, vans, and motor homes (RV) - in both turbo diesel (TD) and naturally aspirated (NA) versions. In addition, low cost and ready availability have made these engines extremely popular the world over for diesel conversion projects; powering Land Rovers, Land Cruisers, and a host of other foreign and domestic production vehicles.
Designed as a diesel engine from the ground up by the Detroit Diesel Division of General Motors, the original 6.2L diesel engine was introduced in the 1982 model year GMC and Chevy C/K pickup truck and full-size SUV lines. Taking this engine design to the next level in the 1992 model year, the new 6.5L diesel engine was an advancement in technology, and was designed for the application of a turbocharger. The 6.2L saw its final year of production in 1993. While the 6.5 was replaced by the Duramax 6600 beginning in the 2001 model year Chevy and GMC vehicle production, the 6.5L diesel engine continues to be manufactured and sold by AM General. AM General is the manufacturer of the civilian H1 Hummer & military HMMWV. Not to worry, support for the 6.2/6.5 will continue to be a big part of The Diesel Page well into the future.
The Diesel Page has expanded coverage of GM's diesel engines since the introduction of the Duramax 6600, which is a result of a joint venture between Isuzu and the General Motors Corporation (forming DMAX Ltd.). We'll have all of the latest test reports and event coverage as that information becomes available for the LB7 / LLY / LBZ / LLM / LMM Duramax 6600 diesel engines, as well as Allison 1000 series 5-speed & 6-speed automatic transmissions. Our professionally written product coverage and bulletin board discussion forum will have the latest information concerning the LB7, LLY, LBZ, & LMM Duramax diesel engines, as well as product reviews covering electronic upgrades such as chips, tuners, and programmers.
Some of the 1980's GM Medium duty trucks and buses recieved an 8.2 Detroit engine.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I wish the 6.2/6.5 thing would not have come up...
They are not "Detroit Diesels", try going to your local two stroke Detroit diesel parts suppler, or even big truck 4 cycle Detroit dealer, you will have a hard time finding 6.2 and 6.5 parts.
The 6.2 and 6.5 were made by GM, but again, not really related to the original "GM Diesel" who made the two cycles, same company yes, but not the same..
Grigg
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Even the old V-6 Toro-Flows and the newer 6.2's and 6.5's were made by the same company, but are completely different engines and were also not considered "Detroits", altho I have heard some mistakenly call a Toro-Flow a Detroit.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Name change from "General Motors Diesel", to "Detroit Diesel", occured in 1965. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Thanks to all for the great info. | | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 95 |
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | They were also known as "Screamin' Jimmy", and a lot of names I'd get banned for repeating here! You'll also find the 2-cycle diesels referred to by their cylinder displacement and arrangement, such as a "6-71" (6-cylinder inline, 71 cubic inches per cylinder), or horsepower rating, "238" (same 6-71, set to produce 238 HP). The 8V-71 is a V-8 arrangement of 71 cube cylinders, in power ratings like 290, 318, 335, and 350 HP versions. The fuel injector nozzle size, max RPM setting and with or without a turbocharger changed the horsepower of the same 568 cubic inch engine.
Then there's the 1,2,3,4 and 6-cylinder inlines, with cylinder displacements of 53 or 71 cubes, a 6V-53, 6V-71, and 6V-92 engine, plus an 8V-92 model.
Then there are the big ones, marine engines up to V-16, with cylinders of 100+ cubes.
Confused yet? Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Number of cylinders, all inline unless followed by a "V", then V-type
51 series: 2, 4 53 series: 2, 3, 4, 6V, 8V, 12V 71 series: 1, 2, 3, 4, 6, 6V, 8V, 12V, 16V, 24V 92 series: 6V, 8V, 12V, 16V 110 series: 6 149 series: 8V, 12V, 16V, 20V
I am sure these are right, but I may have left off a 20V or 24V on some, as I don't know for sure if they were made in some of the series.
Engines bigger than 149 series are not really "Detroit Diesels" but made by the "Electromotive" division of GM, not sure who owns them now, or if they are on their own? These big ones are primarily used by railroad, marine, and power generators.
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Grigg somewhere in all these Detroit post someone had posted a link to a site I think was Detroit owned it listed them all with all their optional hores power ratings neat site. I think you have seen this picture before but the Pete in this shot is a one of a kind truck the nose is 6" longer than a long nose Pete and a few inches wider too. It has a 12V 92 in it and has two 6V 92 blowers and four turbos the HP rating was over 650 http://rides.webshots.com/photo/2076701080096773078TXjCpO | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Just to get things truly off topic. The worlds largest engine is a two stroke diesel. http://cellar.org/iotd.php?threadid=11609Does that mean it's a "Detroit Diesel"? Let's see you shoehorn this one into your bolt Grigg! (smile) | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Yes to the "screamin' Jimmy" name. I've run trucks with those things at full horsepower on a chassis dynamometer- the engine noise alone will drive everyone out of the building. Add lug tires to the truck and you will clear the neighborhood.
Harvester | | |
