0 members (),
329
Mod | | | Forums66 Topics128,168 Posts1,057,100 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | Where can I find a 1946 one and half ton yolk seal | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jack02, are you talking about the transmission or the rear axle yoke? | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | rear end where driveshaft hooks to yoke | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Any good parts supplier should stock them. Try National Seal #411330 N. Thats a zero, not an O. This should be a double seal with a 1/2" felt packing sitting in front of the pinion seal. You dont need to make a new felt seal but I did on mine.
Jeff | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | national seal does not come up when I do a search?? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Your nearest Napa or parts store should carry them on the shelf. You can also get them here at the Filling StationOr search at Rockauto for the part number. Jeff | | |
