| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Took the first ride around the neighborhood in the 1949 3100 after finishing brake rebuild.
Speedo needle was waving at me. What causes this? Cable or speedo head?
Thanks! | | | | | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | I would try lubing the cable first, it is the easiest fix. I have had mine bounce and re-lubing the cable calmed it down.
Good luck... Brent | | | | | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Good advice, lube the cable first and drive for a while to let the grease it do it's work.
I disconnected mine at the transmission, and lubed the bottom third with lithium grease. The center drive cable usually slips out easily - so don't drop it on the ground! | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Lithium grease gets hard when its cold. I'd use either real speedo cable lube or a moly grease. Be sure to work it into the cable. If the cable has any kinks or fraying, replace the cable and the housing.
Fred 52 3600 69 C-10
#3705 07/02/2004 11:51 PM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Gotta agree with Fred on this one. I wouldn't use lithium grease on the cable. That stuff gets rock hard. Some good clear silicone grease works well. And, last's a good long time.
JS | | | | | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I didn't know lithium grease hardened. I use the rattle can lithium grease and it's pretty thin when I apply it.
I'll have to put some in the fridge and see what happens! | | |
