3 members (Leo, treegrower, Eisenholtz), 103 guests, and 2 robots.
Topics128,140
Posts1,056,774
Members48,454
#369331 02/01/2008 10:31 PM
Apprentice
Apprentice
Not sure what I'm dealing with here. It is a Chevy. This wrecker is part of an estate that the family is wanting to dispose of. The vin # is : 1002PN28415A. I ran the # on a web site. It came back as a '61 but the hood is the same style as a '63. Anybody got and idea???? It is for sale if there is any interest. Open to offers. We are in central NC about an hour south of Raleigh. Here is a picture.
http://www.flickr.com/photos/85338536@N00/2232034047/
More pictures here:
Thanks for the help.
Carolina Mike
jdl Offline
Probably a '61 with a '63 hood on it.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Well, it looks like a '62 Chevy to me. It has a '62 grille, but that is a GMC dashboard. It can't see a good enough picture of the hood to say for sure as a Chevy hood and a GMC hood is different. The original side emblems are gone, so that doesn't help either.
I'll get my books out a little later to check on the VIN number, if none one else jumps in till then, but are you sure that first number is a 1 and not a 4?
I like those parts cars by the way. I'm in Virginia, but they are still just a little too far away.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Apprentice
Apprentice
Thanks for the info. I have an update. Posted 2 more pictures on my Flickr page that better show the grill and hood. The vin # that I listed is correct - 1002 P N28415A. I checked it again today. The tag also says Gross HP is 150 @ 3600 RPM, Net HP is 125 @ 3600 RPM. Max GVW is 5200 lbs. The truck is GMC cab because is has GMC sill plates and a GMC steering wheel but the grill says Chevrolet. The truck looks like a '62 to me???? The serial # on the engine is F0413GC. Which engine is this? I suspect the wrecker was a county school bus garage wrecker. Don't think there has been any vin # switching. It is for sure that some parts were switched around. I wish I had the time and I would restore the truck. I think it is a great piece. Thanks for the help.
Carolina Mike
Mike,
It looks like someone put a cab on that truck from a '60 or '61 half ton GMC Pick-up.
The front clip of the truck looks like a '63 to '66 C-50 or C-60 with a '62 Grille.
GMC 9500 Fan
Detroit Diesel Fan
Mike,
I can check on the engine code info for you, but first need to verify that it is a 6-Cylinder engine.
GMC 9500 Fan
Detroit Diesel Fan
Apprentice
Apprentice
Thanks Bill. Your info makes the wrecker more interesting. I suppose in the day, a man did what he had to do to have a piece of equipment to work with. The engine is a 6-cylinder, either a 235 or 261 (I'm hoping that it is a 261). Would the digit after the "F" be a zero or the letter "O"? The engine would better reinforce the fact that the truck is a '61 or '62 Chevrolet with some sheet metal switching. What do you think?
Again, thanks.
Carolina Mike
Carolina mike all the cabs 60-66 C10-C60 were the same size. However that being said The cab shapes and the windshields shape changed 60-63 are the same 64-66 are the same. I was told while doing research on my 65 C50 wrecker. This site and a few others are the greatest for knowledge.
Mike,
I found the GC engine code to be a '71 6-292 from a 1/2 ton truck.
To verify the info, look for a date code on the side of the block, passenger side, towards the back, between the oil pan and the side cover.
The 0 in the engine code is a zero. The 0413 is the month and the day of the engine (April, 13th).
GMC 9500 Fan
Detroit Diesel Fan
Apprentice
Apprentice
The engine is definitely the older 235 style engine not the newer style 230/250/292. I have experience with both. From the serial number, what do you think it is - 235 or 261?
I'm thinking that the truck started out as a '62 frame and front clip. A GMC cab was added when the wrecker body and wench were installed.
Going to try to pull the truck out of the weeds this week end to get a better look at it.
Thanks for all of the help.
Carolina Mike
Mike,
I don't see a "GC" anywhere else, for a 6-Cylinder. Lets try a Casting Number. Also look for a Date Code.
GMC 9500 Fan
Detroit Diesel Fan
That's an interesting combination for sure. Like Bill said, it looks like it could be a pickup cab that someone put on there. A big truck cab should have had the clearance lights on the top. Also, the front bumper looks like the 55-59 vintage, but that could have been put on there too. Do the cab mounts look factory or did someone fab them? As for the engine, I see it has the by-pass hose from the water pump to the thermostat housing. Does anyone know if this was used on the 235 big truck engine or was that a 261 feature only? Just curious.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
Apprentice
Apprentice
Was able to get a little more info from the wrecker this weekend. Did some research on those engines also. The first thing I looked for was the captains bars above the starter that is on the 261's. Sure enough there they were. Then I was able to get the casting number cleaned off to see 3769717 which confirms a 261.
Also looked at the cab mounts. The mounts are stock but pieces of a tire were used to isolate the cab from the frame. So from the info that you guys have furnished I'm thinking that it is a '62 truck with a GMC cab switched out for some reason.
Thanks for all of the help. Going to put it on the swap meet if anyone is interested.
Carolina Mike
