9 members (Wally / Montana, padresag, walter74, Wayne67vert, Shaffer's1950, treegrower, TexasFarmTruck, Otto Skorzeny, 1 invisible),
75
Mod | | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | My rear turn signal bulbs have blown a couple of times. I converted to 12 volts and the correct bulbs are installed. The truck has a 12 volt alternator. The output at the battery with the engine running and headlights on is 14.0 volts average. Without the headlights on, it is showing 14.8 volts of output. Is this right or am I getting too many volts and thus blowing the bulbs? If it is too high, how do you tone it down? It has an internal regulator. I've completely by-passed the old voltage regulator that used to be mounted on the firewall in the 6-volt systems. Thanks. Rick | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may be useing low quality foriegn made bulbs. You may be getting water in the light which burns out a hot bulb. 14.8 is higher then the charging voltage should be but would not cause the bulbs to burn out that soon. It will shorten the life of all the electrical components. The voltage is built in the solid state regulator & the only way to change it is to replace it. That is another part that can be cheap foriegn made. It is possible the battery is at fault also but not likely. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rick,
14.8 is at the top of the scale, but it's OK. This wouldn't be the reason your lamps are exploding. I'm with Wrenchbender on the cause of the problem. It sounds like it's either poor quality bulbs, some type of severe shock to the filament or maybe water splashing on a hot lamp.
Stuart | | | | | Joined: Jan 2008 Posts: 10 New Guy | | New Guy Joined: Jan 2008 Posts: 10 | To add, when you replace bulbs never touch them with your bare hands, use rubber gloves or a clean rag as the oils on your hands tend to over heat the bulbs and shorten their life dramatically. I have seen it happen too many times so I wanted to offer my .02... | | |
