| | | Forums66 Topics128,036 Posts1,055,452 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | I am looking for info on what new front spring to get for a s 10 chassis to hold up a 350 sbc. the truck originaly had a 4 cylinder in it, I have gathered up everything else i need, but haven`t been able to come up with what springs to use. any help anyone?? Thanks Mike Bourg | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I put a V8 in a S10 that had 4 cylinder spring & it looked just fine, BUT normally they say to use the 2.8 or 4.3 springs. I have a 425 Caddy mtr in mine using 4.3 springs w/o a problem..Joe | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You can use springs from a '78-'85 Malibu or Monte Carlo V8. Springs from a 4.3 V6 S10 will work, too, seen plenty of V8 S 10s riding on stock springs without any problems. Also, to get a better ride (especially if you run drop springs), you can use shocks from the malibu on an S10. They're direct bolt ins, just don't need to use the mounting studs for the lower in the rear.
Bill Burmeister | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | Thanks for the info, i`ll hunt down some 4.3 springs. Mike Bourg | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I would love to do a project like that but to use a stovebolt's half ton body.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I would love to do a project like that but to use a stovebolt's half ton body. Why?????????? Heck I did mine using a 1ton Panel/Bus body...Joe | | |
